Pepperheads6
Oct 10, 2024Aspirant
Unknown appa
Has anybody had any issues with unknown apps being blocked and not permitting them to be used? (Ie. Gamma IPTV)
Pepperheads6
I use a nighthawk ax4200. Something is blocking me from updating the app after using it for 2 years
michaelkenward
Oct 11, 2024Guru - Experienced User
Which one?
ax4200 is not a unique Netgear model number. Many devices come with the AC/AX tag, but it is essentially a label that Netgear, and others, attach to hardware to describe wifi speeds.
Look at the label on the device for the Model Number. And, if there is one, include the "V" bit to show the hardware version. If there is no V number, then you have V1.
Updating how? What happens when you try?
This is the most reliable way to go about it:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Just another user with time on their hands.
