zkalmar
Jan 10, 2022Follower
unknown device on home network
Hi All,
Anybody heard of Dark Networking TECHNOLOGY-WRT302, looks like a turkish brand repeater. Might be some wifi
stealing going on at my network.
It shows up on my network as a wired device , altough lot of IOTs shows up like that since they are connected to other wired netgear access points. The Ip adress (ending .2) is right after the main router RAX200 (.1) . Cant' ping it nor bring up the login page....and, I can't locate it physically, any ideas?
Thanks
Maybe this?
Try changing the SSID name and PW on the RAX router temporarily to see if it appears on the routers web page.
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you. - plemansGuru - Experienced User
You could block it using the access control
