netrout7
Sep 01, 2025Aspirant
Unknown Device on My Network
I got a USED Netgear AX1800 Wifi Router From Amazon and I noticed 2 unknown devices on my network, is this be just a memory or history of the devices used from the previous owner? Can the previous ...
CrimpOn
Sep 01, 2025Guru - Experienced User
No. WiFi routers display only devices which are currently connected to the router. It would be helpful to determine which of your devices do NOT appear to be connected.
Modern software for mobile devices (cell phones, tablets, laptops) often enables a feature called "MAC Randomizing"
This results in "strange devices" appearing on networks because they use a MAC address different from their real MAC address.
netrout7
Well I called sutomer service and they said it was most likely from the previous user who owned the device. I blocked those two devices but i felt uneasy so I decided to buy a brand new router instead. I did a factory reset of my router yesterday and it cleared the unknowns and showed only my own 3 devices
But just now, I logged in and I see 3 unknown devices that are not mine: Chromebook laptop, Ideapad and Amazon- i dont own any of those!
I also went to a website i normally go to and 2 times it took me to a completely different website
Is it possible the previous owner (or someone else can hack my router, even after i did factory reset yesterday with Netgear Tech support?
