rbk-rax20
Mar 24, 2022Initiate
Update Breaks Advanced Tab
Netgear AX1800 WiFi Router Model: RAX20 Updated today (2022-03-24) to Firmware Version V1.0.10.110_2.0.72 and now I cannot access the Advanced tab on the router setting page. I looked at the HTML...
Mar 24, 2022Guru - Experienced User
What browser are you using? Happens with other browser?
Be sure to clear out all browser caches.
Try a factory reset and setup from scratch and see.
rbk-rax20
Was using Safari, tested in FireFox and that was the fix. FFS Apple is killing me these days.
Thanks
- FURRYe38Mar 25, 2022Guru - Experienced User
Thanks for letting us know.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
