use2ski
Nov 27, 2021Follower
Update userinterface language
RAX80
Update of userinterface language dont work.
Message; 'Update in progress' running indefinitly.
Actual firmware version V1.0.5.132_1.0.69 is manually downloaded and installed
Actual version userinterface language 1.0.1.70_2.1.46.1
New version userinterface language 1.0.5.132_2.1.46.1
1 Reply
use2ski wrote:
RAX80
Once is usually enough:
Update of user interface language - NETGEAR Communities
And it might help to check the appropriate section.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
