ett3's avatar
ett3
Follower
Aug 05, 2023
Updating LAN settings AX4200
Trying to update Settings >
How do i know when the orbi AX4200 wifi router has finished updating settings on orbilogin.com. The bars have moved all the way across, but it still says updating settings after 30 minutes.
Sorry for the duplicate post.
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Which one?
    AX4200 is not a reliable guide to model number. Many devices come with an AX tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
    Look at the label on the device for the model number.
    How did you update the settings? Using the browser graphical user interface (GUI) and a PC?
    Your subject says LAN settings. Which ones?
    Most updates are instant. It is only something that demands a reboot that takes any time.
