Jollytime
Aug 28, 2019Aspirant
Upgrade from Orbi to AX12
Just purchased a AX series router. I was using a Orbi system (actually went back to until this is solved). I set-up but my FireCube cannot see the 5G network. I have tried a lot of different set-ups...
Jollytime
Sep 04, 2019Aspirant
Disabled AX and Firecube still cannot see 5G network.
Sep 04, 2019Guru - Experienced User
Are you using smart connect?
- JollytimeSep 04, 2019Aspirant
No.
- plemansSep 04, 2019Guru - Experienced UserWhat channels are you broadcasting on? Region set?
Broadcasting on 2.4 and 5 Ghz. It is right out of the box Region should be USA.
Just doesn't make sense that the FireCube can see my old router but not the
new one. (5Ghz only, it sees the 2.4 just fine). I wil play around with different
settings. Luckly I am tech savy, but it still should just "work" out of the box.
firmware on your RAX200?
What modem is it connected to?
