Dstrouse's avatar
Sep 14, 2020
Upgrade to WiFi6e standard
Does anyone know if the RAX120 will be able to be updated to the new WiFi6e standard?
  • plemans's avatar
    Netgear hasn't released any info on upcoming 6E devices.
    And the change is a hardware change. So they can't just "update the firmware" on the RAX120 to support it. Not sure if thats what you're implying but I've seen it asked on here.
  • Technically, even if any Wifi6 router radio supports 6E, you would really need a seperate radio for the 6ghz band.  Therefore expect to see 6E routers at a minimum, as tri-band routers.  I doubt even existing tri-band routers (with a supporting radio) would give up any one radio to switch support for it to 6GHZ.
    • avtella's avatar
      avtella
      Prodigy
      Even with 6E capable radios on some current routers, the rf chips aren't 6E capable so you still need hardware updates, not something software can fix.
  • Did you know that RAX120 even failed the Wifi 6 certification?
