phrostb
Nov 29, 2023Star
Upgraded it's firmware in the middle of the business day to Firmware Version 1.2.13.100
My router seems to have upgraded it's firmware in the middle of the business day to Firmware Version V1.2.13.100_2.0.54 . No change log that I can find anywhere.. Also, I can no longer login with rou...
michaelkenward
Nov 29, 2023Guru - Experienced User
Are you sure that is the RAX500E?
Going from V1.0.12.96 to V1.2.13.100 is out of line with the usual Netgear numbering regime.
The changes are usually in the last two segments.
- phrostbNov 29, 2023Star
RAXE500, yes.
- FURRYe38Nov 29, 2023Guru - Experienced User
Wow, that's a jump for sure. I'll check mine out as well.
- MAD5Nov 29, 2023Tutor
wow, I hope I got mine and can use 6E speeds. I have not that speed since never.
- michaelkenwardNov 29, 2023Guru - Experienced User
That's a giant leap for routerkind.
