phrostb
Nov 29, 2023Star
Upgraded it's firmware in the middle of the business day to Firmware Version 1.2.13.100
My router seems to have upgraded it's firmware in the middle of the business day to Firmware Version V1.2.13.100_2.0.54 . No change log that I can find anywhere.. Also, I can no longer login with rou...
michaelkenward
Nov 29, 2023Guru - Experienced User
Are you sure that is the RAX500E?
Going from V1.0.12.96 to V1.2.13.100 is out of line with the usual Netgear numbering regime.
The changes are usually in the last two segments.
phrostb
Nov 29, 2023Star
RAXE500, yes.
- FURRYe38Nov 29, 2023Guru - Experienced User
Wow, that's a jump for sure. I'll check mine out as well.
- MAD5Nov 29, 2023Tutor
wow, I hope I got mine and can use 6E speeds. I have not that speed since never.
- michaelkenwardNov 29, 2023Guru - Experienced User
That's a giant leap for routerkind.
- rsun0525Nov 29, 2023Guide
So your router just found it in an autoupdate? Mine still showing no update available 😞
- michaelkenwardNov 30, 2023Guru - Experienced User
The reference to:
https://kb.netgear.com/2649/NETGEAR-Open-Source-Code-for-Programmers-GPL
suggests that this release is not yet available on the update server.
New versions usually land in a particular sequence. The first time that regular users are likely to see them is in the downloads library on the support pages for a device.
Support | NETGEAR
Feed in your model number and check the firmware for your device.This give experienced users a chance to manually update the firmware.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
The next stage is to put the release on the update servers so that the router itself will detect it.
