phrostb
Nov 29, 2023Star
Upgraded it's firmware in the middle of the business day to Firmware Version 1.2.13.100
My router seems to have upgraded it's firmware in the middle of the business day to Firmware Version V1.2.13.100_2.0.54 . No change log that I can find anywhere.. Also, I can no longer login with rou...
phrostb
Nov 29, 2023Star
RAXE500, yes.
rsun0525
Nov 29, 2023Guide
So your router just found it in an autoupdate? Mine still showing no update available 😞
- michaelkenwardNov 30, 2023Guru - Experienced User
The reference to:
https://kb.netgear.com/2649/NETGEAR-Open-Source-Code-for-Programmers-GPL
suggests that this release is not yet available on the update server.
New versions usually land in a particular sequence. The first time that regular users are likely to see them is in the downloads library on the support pages for a device.
Support | NETGEAR
Feed in your model number and check the firmware for your device.This give experienced users a chance to manually update the firmware.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
The next stage is to put the release on the update servers so that the router itself will detect it.
