phrostb
Nov 29, 2023Star
Upgraded it's firmware in the middle of the business day to Firmware Version 1.2.13.100
My router seems to have upgraded it's firmware in the middle of the business day to Firmware Version V1.2.13.100_2.0.54 . No change log that I can find anywhere.. Also, I can no longer login with rou...
phrostb
Nov 30, 2023Star
It wasn't working in Firefox but works fine in Edge.. I probably just need to clear cache/cookies.. Other than that, everything seems fine.
And yes, I had auto-update enabled and noticed something strange was happening (got kicked off work VPN for a few minutes). So, I logged into the router to see what the issue was. That's when I noticed it updated it.
Nov 30, 2023Guru - Experienced User
Ok ya, clear cache and should fix that.
Ok sounds good. Keep us posted if you notice anything.
Please test wired and wireless speeds and put the hammer test to it. NG is looking for feed back. Update is only for some units at this time from what NG told me.
- phrostbNov 30, 2023Star
I just ran a speedtest.net test on both desktop and my Galaxy S21 phone (which I believe only supports Wifi 6, not 6E). On desktop, I got 923 Mbps down and 40 up, on my phone I got 808 Mbps down and 40 up. Seems pretty normal to me?
