EastSider01
Apr 05, 2026Follower
Upgrading from Netgear AX1800 to RS300
Hello: I just ordered a new Netgear RS300 router to replace my nearly 6 year old Netgear AX1800 router which will soon be unsupported. Is there an easy way I can keep all my connected network dev...
Apr 05, 2026Guru - Experienced User
No. You'll need to set up the new router from scratch.
However you can use same SSID name and password from the older router for the new router. Once that is set, you wifi devices should auto connect fine.
Try WPA2 and AES Only at first, then try mixed WPA2 and WPA3. Some older device may not connect if WPA3 is present.
