evnpresson
Jan 28, 2020Aspirant
Uploads Causing RAX120 to drop connection
Hello, I am seeing a problem where whenever I am uploading a high volumn data to the AX12 router, my device loses connection. This has happened with my mobile device when I'm running multiple spe...
evnpresson
I should clarify, I've only tested and seen this behavior on the 5Ghz band.
Christian_R
Jan 30, 2020NETGEAR Employee Retired
Hi evnpresson,
You may need to try changing the WiFi channel on the 5GHz band. Let us know how that turns out.
Christian
