Stocktontakos
Dec 06, 2023Follower
Upnp issues
I just recently switched my internet provider to connext fiber. Everything in my house is working fine but when my son tries to use his Xbox it’s getting a upnp not available and throwing strict NAT ...
Dec 07, 2023Guru - Experienced User
Something to contact your ISP about.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Has a power off for 1 minute then back ON with the ISP ONT and router been performed?
Turn off and unplug modem.
Plug in and turn on ONT. Wait 2 minutes for it to connect.
Turn on computers and rest of network.
