VelkySyr
Feb 17, 2020Tutor
USB-connected External Hard drive AX12 RAX120 router
I purchased a Fantom Drives 4TB external Hard Drive which is compatible with Mac's Time Machine, and connected it to my AX12 RAX120 router via USB. The router is running firmward version V1.0.1.114....
avtella
Feb 18, 2020Prodigy
The ReadyShare feature doesn’t support APFS. Use another file system format, listed in the link below are supported formats.
https://kb.netgear.com/24059/What-are-the-USB-drive-requirements-for-my-Nighthawk-router
- racsoboomApr 25, 2020Aspirant
i have the same problem, can access the drive through the readyshare cloud - so the RAX must be able to see it -
but cannot access it from my imac or other computer
i don't fully understand this answer though sorry.
when i click on 'network' in the finder, then RAX120, it says 'connection failed' even with the correct user name (admin) and password :(
- racsoboomMay 04, 2020Aspirant
Did you answer this????
racsoboom wrote:i have the same problem, can access the drive through the readyshare cloud - so the RAX must be able to see it -
i have the exact problem and am thinking of returning the product (aldo got the ax80 extender) :(thx
- themisnJul 24, 2020Aspirant
I purchased a WD My passport Ultra for Mac and can see it shared, but cannot see it when I go on readycloud to see it remotely. I have the exact opposite problem.
