Keller49
Dec 06, 2023Follower
USB connecter Ext HD
With W10, Had Seagate ExtHD usb connected to RAX 80. My network could see and aaccess. After move to W11 Home and new PC, I cannot see the ExtHD connected to RAX 80. What happenedand how do I share...
michaelkenward
Dec 06, 2023Guru - Experienced User
Keller49 wrote:
What happened and how do I share the ExtHD on my network?
SMB. That's just a guess base on limited detail of your system.
Solved: ALL Netgear USB Drive Mapping Issues ReadyShareCo... - NETGEAR Communities
Then again, what does ExtHD mean? If it is just external HD, no problem. If it is an exotic way of formatting a USB device, it may not work.
