gFletch
Feb 08, 2024Aspirant
USB LED (AX10 router)
I've connected a hub for my security cameras and the USB LED is slowly blinking red. The hub is connected via LAN cable. What have I not done that is causing the red light?
Feb 09, 2024Guru - Experienced User
You gave a bunch of generic information.
Plus you put you installed a hub with a usb port but then that its connected via lan cable.
What did you actually install. A model helps more than generics
What router are you connecting it to?
What is connected to the usb port that is blinking red?
- gFletchFeb 09, 2024Aspirant
The cable is an ethernet cable. It connects a hub for security cameras. The router is an AX1800. Model EAX10. Are all of your replies this insulting?
- michaelkenwardFeb 09, 2024Guru - Experienced User
For LAN ports, flashing usually means traffic.
What is that hub? Brand? Is it talking to the cameras over wifi? Or are they also wired?
What is it? EAX devices are a wifi extenders, not routers. Your previous message said RAX10. That's a router.
Where does the USB come in to this? Is that an LED on the router?
What is insulting about asking for details?
I hope you don't find my questions offensive. Troubleshooting depends on understanding what is going on in a network in as much detail as possible.
- plemansFeb 09, 2024Guru - Experienced User
in 100% agreement with michaelkenward . Details are key. We're not trying to be insulting. But we're not there to see what you have, what you're using, what you've done, etc. We're trying to troubleshoot through a forum and getting limited info. And not always correct info as Netgear doesn't have an EAX10.
and it could be the hub you have only connects at 10/100mbps speeds. That could cause a red ethernet light.
https://kb.netgear.com/24244/What-do-the-LEDs-on-my-NETGEAR-router-mean
But we really can't tell you for sure without details of what you have for router and hub that you have connected.
