gFletch
Feb 08, 2024Aspirant
USB LED (AX10 router)
I've connected a hub for my security cameras and the USB LED is slowly blinking red. The hub is connected via LAN cable. What have I not done that is causing the red light?
michaelkenward
Feb 09, 2024Guru - Experienced User
Which router do you own? AX10 is not a unique Netgear model number. Many devices come with the AC/AX tag, but it is essentially a label that Netgear, and others, attach to hardware to describe wifi speeds.
Look at the label on the device for the Model Number. And, if there is one, include the "V" bit to show the hardware version. If there is no V number, then you have V1.
gFletch
Feb 09, 2024Aspirant
The label shows AX1800. Model RAX10.
