milanski's avatar
milanski
USB not recognising RAX50
RAX50 (Australia)
Hardware VersionRAX50
Firmware VersionV1.0.2.82_2.0.50
GUI Language VersionV1.0.2.82_2.1.46.1
SEAGATE NTFS formated 4TB drive not being recognised.  Works connected to PC.  Please help.
From the manual it says it should work:
The router supports the following file system types for full read/write access:
• FAT16
• FAT32
• NTFS
• NTFS with compression format enabled
• Ext2
• Ext3
• Ext4
• HFS
• HFS+
1 Reply
  • To add to the problem, seems like NO USB is seen by RAX50.  Tried a 8GB flash drive, 32GB, 2TB WD
