coyote3's avatar
coyote3
Guide
Jul 18, 2022
use 'aggregate ports' 1 & 2 separately?
On my RAX120 I don't want to aggregate ports 1 and 2, and have not in the settings.  So can I use ports 1 and 2 as separate LAN ports?   (If it matters, I'm already using the MultiGig port as a LAN...
  • plemans's avatar
    Jul 18, 2022
    yes you can. You don't have to use port aggregation. Its just an option.
