STEVEORENO1
Dec 28, 2022Aspirant
USED R6700AX REGISTRATION PROBLEM
I bought this router off ebay, but the previous owner registered it. How can I register it now and change wifi password?
Dec 28, 2022Guru - Experienced User
You don't need to register it to use it.
Start with a factory reset. Push and hold reset for 7-15 seconds. then follow the install guide (I recommend manually and not using the app).
You can find guides/manuals here:
https://www.netgear.com/support/product/r6700ax.aspx
- STEVEORENO1Dec 28, 2022AspirantI am using it, but I want to change the wifi password, so I believe I have to register it to do so......
- FURRYe38Dec 28, 2022Guru - Experienced User
No you don't need to register to change the wifi PW. Just log into the routers web page at 192.168.1.1 and use the "admin" name and password you set for the routers web page to get in.
