STEVEORENO1
Dec 28, 2022Aspirant
USED R6700AX REGISTRATION PROBLEM
I bought this router off ebay, but the previous owner registered it. How can I register it now and change wifi password?
STEVEORENO1
I am using it, but I want to change the wifi password, so I believe I have to register it to do so......
Dec 28, 2022Guru - Experienced User
No you don't need to register to change the wifi PW. Just log into the routers web page at 192.168.1.1 and use the "admin" name and password you set for the routers web page to get in.
