wvcaudill2
Apr 19, 2021Aspirant
Using ATT BGW210 and Netgear RAX20 Simultaneously
Hey all,
Apologies if this has been answered before, but I've spent the past 2 days trying to understand how to make this work and I've only succeeded in confusing myself even more.
I've got an ATT BGW210 Router connected to the fiber ONT and a Netgear RAX20 (AX1800) router connected to one of the BGW210 LAN ports.
I would like to set this up as a sort of mesh system whereby I can have both devices providing WiFi simulatenously. Is this possible?
I've seen plenty of posts where the Netgear has been set as the only WiFi device, but not where both devices are used as an access point.
No.
Neither the BGW210 or the RAX are mesh routers.
You can set them with the same ssid but devices wouldn't roam between them like a mesh network.
You can connect the RAX to the BGW and continue to use both wireless's but make sure to put the netgear in AP mode or the netgears IP address into the BGW's dmz.
- wvcaudill2Aspirant
Ok, I put the Netgear into 'AP Mode." After rebooting I did lose access to the router through routerlogin.net and the Netgear app. Is this expected?
If I needed to make any changes to the SSID or password in the future would I have to completely reset the router?
You should be able to log into the bgw and look at its attached devices page. that page should have the ip address from the netgear.
- Razor512Prodigy
While you will not get features such as 802.11v and r with such a setup, if you put the Netgear router in AP mode, and give it the same SSID and password, then you will have an overall single SSiD andd roaming will be handled entirely based on the client devices roaming decisions. Most clients will roam based on RSSI values set by the WiFi drivers, e.g., some may decide to roam at -70dB while others may look to roam sooner.
From a networking standpoint, a having multiple different WiFi routers just set up as APs, with wired connections back to the main router, will function fimilarly to modern mesh systems, though the APs will not assist in the roaming process, such as directing a client to roam to a specific AP.
With a wired backhaul, performance will still be very good for each AP.
The only time you will run into some annoyances is if you are using a very old WiFI device which tend to be sticky clients that won't roam unless the client device has too many corrupt frames as the lowest MCS index, for newer ones, they tend to be more well behaved in not letting things get that bad. Forthermore some newer devices using low end and obscure WiFi chipsets, also tend to be bad with client directed roaming.
If your devices are fairly modern with decent quality WiFi chipsets, then setting the RAX20 in AP mode, will offer you a mesh-like experience for those devices (as long as you give both wireless routers the same SSID and password) The response times between changing locations and a roaming event will just be slower than on a true mesh system when various roaming assist features to direct and speed the handoff.
