FluidFactors018
Oct 30, 2021Guide
Using Netgear router directly with CenturyLink ONT?
I'm trying to set up my RAX200 to directly connect to CenturyLink's ONT (without their monthly-rental router in between), and while I've heard it works, I've been unable to get it working myself. For...
FluidFactors018
Nov 13, 2021Guide
As it turns out, it was a CenturyLink issue - Their ONT wasn't working (the "Service" light had never illuminated), and once they swapped a new one in and activated it, I was able to connect with their router. With that accomplished, switching to the Nighthawk took the following changes (after plugging the Nighthawk directly into the ONT):
Under Basic->Internet
1) Set "Does your Internet connection require a login?" to "Yes"
2) In the "Login" and "Password" fields beneath, enter your PPPoE username and password, obtained in one of three ways:
a) Log in to your CenturyLink router and find it in the router settings
b) Contact CenturyLink support via chat
c) Walk through the steps at http://connect.centurylink.com/, and in the process they will display your username/password. In my case, this version included the"@centurylink.net" domain at the end, (<username>@centurylink.net>), unlike what CenturyLink sent me via chat earlier, so I included the domain to be precise
3) "Connection Mode:" "Dial on Demand"
Don't forget to "Apply" your changes and then navigate to...
Under Advanced->Advanced Settings->VLAN / Bridge Settings
1) Enable VLAN / Bridge Setup: Check (to enable)
2) Choose "Enable VLAN Tagging", VLAN ID: 201, Priority: 0, Wired Ports: All, Wireless: All
When you hit "Apply", your router will reboot, and you should have a connection.
Thanks everyone for the help! I hope this saves someone else some time.
FluidFactors018
Nov 13, 2021Guide
...and for what it's worth, I tested with and without the "@centurylink.com" on the PPPoE login, and both worked for me. In addition, with PPPoE enabled, you may need to reduce your MTU to 1492 (Setup->WAN Setup->MTU) to account for PPPoE overhead.
