franlewandoski
Aug 31, 2020Aspirant
Using Nighthawk RAX45 with Fios -- it doesn't connect to internet
Hello, I just purchased the Nighthawk RAX45 at Costco to use with my Fios account. The nighthawk will not connect to the internet. Can you advise?
1 Reply
- Christian_RNETGEAR Employee Retired
Hi franlewandoski,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
http://www.netgear.com/support/contact.aspx
Christian
