Upperdeck
Sep 06, 2023Aspirant
using the built in vpn behind another router
Is there any instructions on using the netgear VPN service. My setup is that i have the ISP router/modem which is sending everything around the house just fine. What I wanted to do was add a ...
Sep 06, 2023Guru - Experienced User
Be sure you have the DMZ enabled on the 1st router for the 2nd router to avoid the double NAT condition which can cause the VPN to fail.
