Upperdeck
Sep 06, 2023Aspirant
using the built in vpn behind another router
Is there any instructions on using the netgear VPN service. My setup is that i have the ISP router/modem which is sending everything around the house just fine. What I wanted to do was add a ...
Kitsap
Sep 08, 2023Master
Upperdeck wrote:calex 844E-1
yes my vpn router has a static ip assigned.
I just dont think the ISP router is passing the traffic back to the VPN router
I have 2 isps at my house and maybe I just pull the plug on this and remove the other isp router and replace it with this VPN router and see if I can go the other way with this stuff.
Possibly an issue with the DMZ configuration on the Calex. There is another unknown device between the Calex router and the internet. Cascading several devices, any one of which could prevent establishing a VPN connection.
Upperdeck
Sep 11, 2023Aspirant
So I gave up and started over. I put my r6900p in place of my fios router and restarted my VPN service.. I download the client connection from the router and put them on my PC and still no luck
Is there some place with actual instructions on how to make this work?
All it does is like before just sit with a connecting message.
