Upperdeck
Sep 06, 2023Aspirant
using the built in vpn behind another router
Is there any instructions on using the netgear VPN service. My setup is that i have the ISP router/modem which is sending everything around the house just fine. What I wanted to do was add a ...
Upperdeck
Sep 11, 2023Aspirant
A little more success..
I had to add a data-ciphers line instead of the cipher line
I had to start the gui as an administrator, and now I can get the gui to say its connected
Once connected the speed is so slow as to be almost unusable..
I ping something like www.espn.com and it takes 20-30 sec per hop..
I still dont see the outgoing public IP being changed yet.
Kitsap
Sep 11, 2023Master
Upperdeck wrote:A little more success..
Your VPN throughput capacity will be the lesser of your ISP upload/download capacity.
The CPU on your R6900P is not the most robust for this application.
Do you have any of the following features enabled?
Smart Connect, Dynamic QOS, Traffic Meter, or Access Control. If yes, they put additional load on your CPU and should be disabled.
Is IPv6 enabled? If your ISP supports it, it should be enabled.
What are your ISP connections to the internet? Fiber, cable broadband, satellite, DSL, or ?
