sanmeet
Mar 25, 2021Guide
usually Cant access 192.168.1.1 plus readyshare unaccessible
issue 1: I have RAX80 with latest firmware. Im rarely able to connect to 192.168.1.1. Im using windows 10 pro laptop and connected via wifi to RAX80 Even connecting via android app shows Rax80 d...
- Mar 27, 2021
OK Fiddling some more helped me to get access to HDD on routers USB...sharing here as it might help others like me:
changes I made as per link shared with me by someone here
1) Enabled SMB1 as per above
2) Also, I marked the wifi network as private (it was public by default) from "open network and Internet settings" by right clicking wifi icon.
3) Also I was prompted to turn on network discovery when I clicked on network on "This PC"
SO the issue is solved for now:-)
moramay
Mar 26, 2021Aspirant
sanmeetclicksud wrote:issue 1:
Even connecting via android app shows Rax80 disconnected 9 times in 10. Im connected to internet just fine via the router. Ping 192.168.1.1 works fine
Issue 2:
I have two usb drives connected to the two usb ports of router one 4TB with external power, another 2TB portable one. Router page shows both drives connected but Im neither able to access any via \\readyshare locally. Also when i try to access via ReadyCloud..I see RAX80, when I double click it, it shows "No volumes or USB disks"
What am I doing wrong?
This will be helpful for you..?
