ascend1230
Apr 18, 2023Tutor
UTP Connection Timeout
I have an end user who is using a RAX50v2. They are having calls with their SIP phone disconnect after 5 minutes or so. Spoke to our phone company and they first had us verify SIP/ALG was disabled,...
ascend1230
Apr 18, 2023Tutor
I'm not sure on the modem, I do know the ISP is OmniTel Communications.
The phone is a Yealink T46S, the phone company is Momentum Telecom.
Apr 18, 2023Guru - Experienced User
MIght find out what their home gateway/ont is. That can be causing issues too.
Do they have ipv6 enabled?
Also, they can try setting the phone with a reserved IP address in the router and then setting that address in the netgears DMZ
- ascend1230Apr 18, 2023Tutor
The modem is a Cyberlink, I do not have the model.
IPv6 is disabled on the router.
I'll talk to the phone company today about using the DMZ.
- michaelkenwardApr 18, 2023Guru - Experienced User
That could be essential. Hard to diagnose without complete details.
There is usually a label on the modem with that information.
