Justbry
Oct 02, 2019Aspirant
Uverse TV not working with Router
I installed the AX8 router last night to help with my speed on the internet, everything is now working as I hoped it would except for the Uverse tv's are freezing up every 10 seconds after changing c...
jkprinc
Feb 15, 2020Aspirant
I am having the same exact problem descibed here, with my new RAX-40, how was it resolved?
Justbry wrote:I installed the AX8 router last night to help with my speed on the internet, everything is now working as I hoped it would except for the Uverse tv's are freezing up every 10 seconds after changing channels. The channel would play for a few seconds then freeze up, I would change channel it would work for 10 seconds then freeze, on and on for every channel. The tv next to the router is fine but all the other tv's in the house this would happen to. The internet signal I am getting throughout the house is excellent with this new router except for the tv. The uverse modem I am using is BGW210-700...any thoughts on how to fix this?
Feb 19, 2020Guru - Experienced User
jkprinc wrote:I am having the same exact problem descibed here, with my new RAX-40, how was it resolved?
If you're using the BGW210, it has an integrated router with its modem. ATT is horrible at setting up their devices to run well in passthrough/modem only mode. And it can impact uverse.
Have you tried leaving the ATT device in router mode (potentially disabling wifi) and running the RAX in access point mode?
