cestmoijay
Apr 05, 2023Aspirant
V1.0.12.120_2.0.83 RAX45 - unable to modify Guest Wifi to allow guests to see each other?
i am on netgear firmware version V1.0.12.120_2.0.83 and i cannot update the guest network setting to allow guests to see each other on local network! i am really gun-shy now in updating firmwar...
Apr 05, 2023Guru - Experienced User
If it worked on last FW version, then go back to that.
- cestmoijayApr 06, 2023Aspirant
That is the obvious thing to do... I have had to do this (it seems) every other firmware update... it's getting really old! Last issue was that I couldn't print (opposite) where my local network wifi should be able to see each devices (not guests) but they couldn't see each other until I upgraded to the last firmware which then worked.
They must be hiring green engineers, right out of school of dummies or it seems.
- FURRYe38Apr 06, 2023Guru - Experienced User
Is there a screen capture of the Guest Network page with v.120 FW loaded that you can post here?
