PinkstonMatt
Oct 01, 2023Aspirant
Verizon FIOS with Netgear Nighthawk AVX AX4300 YouTube TV SPotty
Terrible performance and buffering using Youtube TV Run 5g Tests and its above 300 I am about to give up on this whole streaming crap and go back to cable HELP... am I missing a setting?
PinkstonMatt
Okay let me try to be more clear
I have Verizon Fios into my house directly into a Netgear Nighthawk AX430 RAX45
I have tried eithernet direct to TV (Samsung newer model) from Nighthawk and 5g and in either case I get constant pauses
Firmware says up to date Firmware Version V1.0.12.120_2.0.83
Kitsap
Oct 01, 2023Master
PinkstonMatt wrote:Okay let me try to be more clear
You still have work to do. The RAX45 does not have a direct fiber input connection.
Between the end of the fiber connection and the RAX45 is a device known as an Optical Network Terminal (ONT).
What is the brand name and model number of your ONT? Look on the label.
Knowing the model number of your ONT will allow assistance in configuring your RAX45.
