komodomoe's avatar
Sep 12, 2020
Verizon Gigabit Speeds Slow (60-90mbps)
I am only getting download of 60 Mbps and upload of 93 Mbps with Verizon Gigabit. I have contacted support but they claim everything looks fine on their end and despite restarting the router, I am st...
  • plemans's avatar
    Sep 13, 2020
    Try a different ethernet cable. Make sure its cat 5e or greater.
    You're correct in that the statistics are only showing it connected at 100mb. So its either the modem causing it, the cable causing it, or the rax120.
