komodomoe
Sep 12, 2020Tutor
Verizon Gigabit Speeds Slow (60-90mbps)
I am only getting download of 60 Mbps and upload of 93 Mbps with Verizon Gigabit. I have contacted support but they claim everything looks fine on their end and despite restarting the router, I am st...
- Sep 13, 2020
Try a different ethernet cable. Make sure its cat 5e or greater.
You're correct in that the statistics are only showing it connected at 100mb. So its either the modem causing it, the cable causing it, or the rax120.
Sep 13, 2020Guru - Experienced User
komodomoe
Sep 13, 2020Tutor
I think you're right on the wiring, I spent an hour with customer support and even hooked up my computer directly to the line. They are confident everything is fine on their end with the ONT and the cable plugged into the wall is cat6. The line between seems like the only other suspect. The router is fine, i'm fairly sure. Thanks for the assistance.
