komodomoe
Sep 12, 2020Tutor
Verizon Gigabit Speeds Slow (60-90mbps)
I am only getting download of 60 Mbps and upload of 93 Mbps with Verizon Gigabit. I have contacted support but they claim everything looks fine on their end and despite restarting the router, I am st...
- Sep 13, 2020
Try a different ethernet cable. Make sure its cat 5e or greater.
You're correct in that the statistics are only showing it connected at 100mb. So its either the modem causing it, the cable causing it, or the rax120.
komodomoe
Sep 21, 2020Tutor
Turns out the guy who installed my wall jack miswired it. After the tech came out and rewired the wall jack everything worked fine. As an aside, he decided to do a really ugly mid cord splice on a new tip for the ONT side. Now I have a mess of unjacketted wire over there 😳
Word to the wise, if you know how to retip Cat6, do it yourself.
I wouldn't have thought any connection would be possible with the wiring improperly connected but apparently you can. Oh well. Thanks for the help everyone.
- plemansSep 21, 2020Guru - Experienced User
Glad to hear you got it resolved!
let us know if you have further issues and we're happy to help
