WA4CUA
Oct 29, 2021Guide
VERY POOR NAS AND FTP PERFORMANCE
I have FTP enabled on my RAX-80 Router and a hard-wired network connected Windows 11 PC. The ftp drive on my Router is a WD EasyStore 8TB USB 3.0 Drive. The ftp drive on my PC is an internal hard d...
Razor512
Oct 29, 2021Prodigy
Those results do not seem normal, what file sizes are you dealing with?
Also how do the results compare if you use the smb share (in windows explorer doing something like \\routerIP )
Is SMB really slow as well or is is it at least able to get close to saturating a gigabit wired connection?
Also how does the FTP performance cmpare when using windows file explorer when you do ftp://router IP ?
One area where the FTP server and smb shares can struggle is if the device iis accessed in a way that lean to heavily on high IOPS for the desired operation.
Razor512
Oct 29, 2021Prodigy
Wanted to clarify further. are the files mentioned single large files, e.g., a 30+ GB .vdi file where the real time protection will not attempt to scan the contents of the file, or is it a folder or something where your AV software will get bogged down scanning everything or trying to access a ton of files on readyshare at the same time as that causes massive slowdowns on the router since the file server functions and shares are single threaded.
- WA4CUANov 05, 2021Guide
Please read my first post literally.
My brother (300 miles away) tried downloading via internet the same 30 GB file copied on two different ftp servers: my RAX80 router, and a Windows 11 PC. The reported file download speeds were 1.2 and 5 MiB/s, respectively. In addition the ftp file transfer failed after 15 GB transferred from the Router.
My brother's PC had the same computer and ftp client for both attempts.
It seems from other posts that Netgear in general shows poor performance using any methods of transferring files via its USB ports, be it ReadyShare or other protocols.
I guess Netgear needs to hire some better programmers, unless the problem is really in the hardware.
Netgear seems to be avoiding posting any company-sanctioned reply to this issue.
- Razor512Nov 05, 2021Prodigy
To me, it definittely seems like there is an issue with either the device connected to the router or a configuration issue. The RAX80 is able to fully saturate a gigabit Ethernet connection for both reading and writing to USB storage.
