ByteBiter
Sep 20, 2024Follower
Vivaldi browser not syncing over LAN but can sync over WIFI
Hardware: RAX200 Firmware: V1.0.10.140_1.0.79 I use the Vivaldi browser, which syncs its settings across computers. I have been running into the following issue. I have multiple computers conne...
Sep 20, 2024Guru - Experienced User
might check on that pc if you have any security, vpn, or ethernet settings.
Have you tried the other devices wired?
Or have that pc set with a public address and not private when on ethernet? (check in your windows settings)
