sqpstar
Apr 28, 2025Aspirant
VLAN setup on RAX120
Hi, I am looking for some help setting up VLANS with RAX120v2 router. I just built an opnsense firewall which will be sending vlan 3 different vlan tags over its lan interface to the RAX120. I wa...
schumaku
Apr 29, 2025Guru - Experienced User
No Netgear consumer devices come with any kind of VLAN support on the LAN side.
The config you are referring is for bridging an ISP Internet connection which can be tagged e.g. for the Internet IP side, or for some exceptions an IPTV VLAN on the WAN side, which can be bridged to one or some selected LAN ports to connect an IPTV Set--top box, alternately to a selected Wi-Fi adapter (==interface).
These features are intended for a specific usage only, in no aspect to define a Multi VLAN config for the LAN side.
- sqpstarApr 29, 2025AspirantThanks very much for the clarification. I am not looking for the tags to be passed through to the lan. Only expecting untagged traffic in the set vlan on the Internet side. Will this work?
- schumakuApr 29, 2025Guru - Experienced User
Only for the case your ISP does require tagging for the internet connection, or for the special case where IPTV is offered on a dedicated VLAN. Like I said, these are not generally available as universal VLAN support. Nothing for your security appliance....
- sqpstarApr 29, 2025AspirantThank you. I will invest in a decent access point.
