sqpstar
Apr 28, 2025Aspirant
VLAN setup on RAX120
Hi, I am looking for some help setting up VLANS with RAX120v2 router. I just built an opnsense firewall which will be sending vlan 3 different vlan tags over its lan interface to the RAX120. I wa...
sqpstar
Apr 29, 2025Aspirant
Thanks very much for the clarification. I am not looking for the tags to be passed through to the lan. Only expecting untagged traffic in the set vlan on the Internet side. Will this work?
schumaku
Apr 29, 2025Guru - Experienced User
Only for the case your ISP does require tagging for the internet connection, or for the special case where IPTV is offered on a dedicated VLAN. Like I said, these are not generally available as universal VLAN support. Nothing for your security appliance....
- sqpstarApr 29, 2025AspirantThank you. I will invest in a decent access point.
