tmparisi
Feb 05, 2025Follower
VOIP devices initially connect to network then drop (obtaining IP address)
if a phone is unplugged and then plugged back into router, it will not work. it will initially connect and give ip address, then it drops about 10seconds and consistnetly says obtaining ip address. ...
Feb 05, 2025Guru - Experienced User
Is this the RAXE300?
What is the brand and model# of this phone device?
Be sure to use good quality LAN cable. CAT6 UTP is recommended.
Set up a IP address reservation for the phone device?
Use the DMZ on the router for the phone device?
