Milk_Money
Nov 30, 2020Follower
VPN Config On Rax80
Im setting up VPN configuration on my router. I downloaded and configured the sofware. Changed the connection name and not able to connect. The default ports are 12973 on "TUN and 12974 on "TAP" when...
Christian_R
Dec 08, 2020NETGEAR Employee Retired
Hi Milk_Money,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
