cjlundeen
Mar 10, 2021Follower
VPN issue
My roommate uses watchguard VPN to access her job. It works just fine when connected direct to the modem or to the router but on a wireless connection she connects then cannot open or access anythin...
Christian_R
Mar 15, 2021NETGEAR Employee Retired
Hello cjlundeen,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
