bonneyt214
Jun 20, 2021Aspirant
VPN not connecting
Yet another "I can't connect", but... I have tried this with windoze 10, linux (fedora 32) and my android phone (galaxy s9). I followed the instructions from the admin web page: downloaded the zi...
bonneyt214
As I said, I followed the instructions from the router's admin page - exactly.
- I did use the OpenVPN app from the android store. If necessary, I can post the logs from it.
- I do have a DDNS (thank you mynetgear.com).
- My connection is from the cable modem to the WAN port on the router (via a switch). No port forwarding, not connecting from the LAN.
- And, again, I did follow the instructions - without missing any steps - for windoze (use TAP, change names, etc.). And running wireshark on that system had the same result: packet sent to the router, packet returned from the router.
I have set up vpn's on linux boxes before, both client and server. So I am not a complete NOOB. And since there is no debug info from the router itself, though, I can't say what it is, or is not, doing. But all of the connections to the router and client machine are set as per specification, and from my experience, should be correct.
Razor512
Jun 20, 2021Prodigy
In that case, you will need to check the logs, also check if the client you are using is still allowing the encryption type to be used (especially needed on older routers that will be using an older version of the server).
