Kizziar
Apr 23, 2021Aspirant
VPN on a RAX78 router
Well it's really a RAX78 but I wasn't offered that option and the rest of the discription fits. Anyway this Netgear router actually has a VPN client option. First I've found on a Netgear router. But...
Christian_R
Apr 29, 2021NETGEAR Employee Retired
Hello Kizziar,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
Kizziar
Apr 30, 2021Aspirant
Hey Christian, thanks but they sent me to the community. It seems they didn’t know the Rax78 had VPN capability let alone if I could change the list VPN server.
- Christian_RMay 03, 2021NETGEAR Employee Retired
Hi Kizziar,
The RAX78 currently only supports OpenVPN. You may find more info on page 138 of the user manual linked below.
https://www.downloads.netgear.com/files/GDC/RAX70/RAX70_RAX78_UM_EN.pdf
Christian
