Kizziar
Apr 21, 2021Aspirant
VPN on RAX78 router
Hi guys, I have a RAX78 computer and was surprised to see it has a VPN client capability but when I looked into it the only VPN server that is usable is PureVPN. I already have a subscription with Su...
michaelkenward
Apr 22, 2021Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads.
