mnhim001
Jan 16, 2024Aspirant
VPN passthrough not working
Hi, I have the Netgear Router RAXE500 and have VPN set up and have been using it since the day I got it. Just recently, when connected to the VPN, I don't get any Internet or local access pass t...
- Jan 19, 2024
mnhim001,
I reverted back to V1.0.12.96_2.0.45 and the VPN is now working properly...
You might want to give that a try before jumping through a bunch of hoops for Netgear support...
Kitsap
Jan 17, 2024Master
mnhim001 wrote:Hi,
I have the Netgear Router RAXE500 and have VPN set up and have been using it since the day I got it. Just recently, when connected to the VPN, I don't get any Internet or local access pass through. There isn't much configurations to do on the Netgear VPN setup page. Does anyone know what's going on? I am using OpenVPN from my Android phone.
I've changed it from UDP to TCP, and then TCP back to UDP with no luck.
I am running the VPN server on my R9000. Attached is a snip from my configuration page. Your newer RAXE500 will look a little different in the format.
How long has it been since you updated the configuration profile on your phone?
- mnhim001Jan 17, 2024Aspirant
I have updated them yesterday, as well as several times when this started happening.
I do have the same settings selected as you do.
- KitsapJan 17, 2024Master
On several Android devices, we are using OpenVPN Connect version 3.3.4.
Not sure where you are connected when you are doing the testing. You cannot be connected to Wi-Fi that is part of the same network where the OpenVPN Server (on your router) is running.
- mnhim001Jan 17, 2024AspirantI tried it using my phones mobile data with wifi turned off. I also tried it at work, using my works wifi.
