mnhim001
Jan 16, 2024Aspirant
VPN passthrough not working
Hi, I have the Netgear Router RAXE500 and have VPN set up and have been using it since the day I got it. Just recently, when connected to the VPN, I don't get any Internet or local access pass t...
- Jan 19, 2024
mnhim001,
I reverted back to V1.0.12.96_2.0.45 and the VPN is now working properly...
You might want to give that a try before jumping through a bunch of hoops for Netgear support...
Kitsap
Jan 17, 2024Master
With your VPN connection established, on another device on your LAN, can you log in to your RAXE500 and see your phone as a connected device?
Have you checked the connection logs generated by the OpenVPN Connect application?
Do you use a service like No-IP for Dynamic Domain Name Server?
mnhim001
Jan 18, 2024Aspirant
I was able to view the log and I see the GW and DNS as 192.168.254.1. This is not the local IP of my router. I had reassigned it when I first received the RAXE500. Can this be the issue? If so, how do I even change it within the router?
With VPN connected, it does show on my RAX500 that I am connected. I was able to check RAXE500 on a LAN connected workstation.
For testing, I used my mobile data to connect to VPN, then tried to access the RAXE500 admin page and it failed. After disconnecting from VPN, tried the admin page again and it worked via the same device.
I am using the DDNS option built into RAXE500 which is hosted by No-IP. It's a turn on or turn off function, nothing to configure on that page.
- KitsapJan 18, 2024Master
I am using the DDNS option built into RAXE500 which is hosted by No-IP. It's a turn on or turn off function, nothing to configure on that page.I presume you have a valid login at No-IP and pay their annual fee?
What device, brand name and model number, is upstream of your RAXE500 between it and the internet?
- mnhim001Jan 18, 2024Aspirant
I am only using the no-ip free account. So, I log in monthly to keep the name alive.
I have fiber with hardware provided by Frontier. I don't have that information with me at the moment.
- jericonstJan 18, 2024Aspirant
I am having the same issue and have been working with Netgear support for a while on this. They are unable to find a fix for the issue so far. Maybe a firmware update is needed to get this fixed?
