mnhim001
Jan 16, 2024Aspirant
VPN passthrough not working
Hi, I have the Netgear Router RAXE500 and have VPN set up and have been using it since the day I got it. Just recently, when connected to the VPN, I don't get any Internet or local access pass t...
- Jan 19, 2024
mnhim001,
I reverted back to V1.0.12.96_2.0.45 and the VPN is now working properly...
You might want to give that a try before jumping through a bunch of hoops for Netgear support...
mnhim001
Jan 19, 2024Aspirant
It does show private key, but does not show as an RSA private key.
jericonst
mnhim001,
- KitsapJan 19, 2024Master
jericonst wrote:mnhim001,
You do not have the same issue as jericonst. However, his information was informative.
Back to the question, what device brand name and model number is upstream of your RAXE500? Configuration of that device can block the RAXE500 from having access to the internet via OpenVPN.
For test purposes, you might want to revert back to the firmware version noted above. If you do, be sure and turn off automatic firmware updates. Also you should create a new set of configuration files with the old firmware.
- mnhim001Jan 19, 2024Aspirant
I think its an issue with port forwarding. I opened up a port trying to setup WireGuard and that still didn't work.
I went to https://www.yougetsignal.com/tools/open-ports/ to check if my port was open and it shows closed.
Again...sorry I forgot to gather the information you needed on my Fiber hardware.
- c4rlocoFeb 01, 2024Tutor
I am also experiencing the same issue (VPN Passthrough is not working). I can connect with errors to the VPN but I cannot browse any website.
I opened the case# 48002888 in case this helps.
- mnhim001Feb 01, 2024AspirantGo back 1 firmware.
Absolutely. That was the only way to get the VPN Passthrough working. Going back to V1.0.12.96_2.0.45
NG needs to definitely do a better job with these releases.
